Inspire & Inspire HR Firmware Update: Version 1.57.15
ANSWERED
Fitbit update 3/16/19: Due to an issue regarding Chinese locals. Our team has updated this firmware release to a new version (1.57.19). This update does not change from the functionality of the previous build. Both versions should function the same for all users.
Hi all! Robot Very Happy
I'm excited to announce that a new firmware version has been released to 100% of users for both Inspire and Inspire HR! (Version: 1.57.15)
WHAT’S NEW AND FIXED
You can now see additional daily stats on your wrist, including sleep duration, water intake, and more.
This release includes bug fixes and improvements.
HOW DO I UPDATE?
Step by step instructions for updating your tracker can be found here.
If you run into any trouble updating your Inspire or Inspire HR, I recommend reviewing these troubleshooting tips
Looking forward to hearing everyone's feedback on the latest release. If you have any questions, feel free to let me know!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
32 REPLIES 32
Hi @LBE Unfortunately you cant turn them off.
Community Council Member
Helen | Western Australia
Hello, and thanks. I just got my Inspire HR Friday (3/29). I upgraded from an Alta HR.
When I set it up, it updated to the new firmware, 1.57.19. I wonder if there is a way NOT to see water intake and weight? It would be great to be able to select the stats most useful to me.
So far I love the Inspire HR, but I have to say that even with the Simple Stats clock face, the battery life is nowhere near what I would get from the Alta HR. I find I have to charge the Inspire HR every couple of days. I hope that gets better.
Don't let the stars get in you eyes, Don't let the moon break your heart.
My new inspire is not responding after update, display is dimm (off), and it is unable to restart..
Please help me
Hello guys, I hope you are doing fine.
I appreciate all the efforts in trying to fix this update issue by yourselves.
@N8teGee@NellyG and @sailorbear510, thanks for the input.
@Rainyrivers, if you are having issues updating your Fitbit, I recommend taking a look at the help article Why can't I update my Fitbit device? and follow the instructions provided there.
@Larniegh, if you are seeing the fitbit.com/setup on the screen, that means that the device isn't paired. Please follow the steps in the help article Why can't I set up my Fitbit device?.
@LBE and @catester, as our friend told you, there isn't an option to rearrange those stats. I took the liberty and searched for a request like this but didn't find any. Feel free to visit our feature suggestions board and share your ideas.
@JurajKa, have you tried to change the clock face? If you haven't, I suggest trying this by following the instructions in the help article How do I change the clock face on my Fitbit device?.
Keep me posted. Smiley Wink
Thanks - I had already gone over to the feature request with this. I appreciate the feedback.
Dear all,
it is definitely irreparable..
My Fitbit Inspire will be replaced with new one.
I just purchased the Inspire and clip to replace my One which sadly, Fitbit has discontinued. The online User instructions tell me to check the On Clip button to tell my Inspire that it is on the clip, but there is no button for On Clip. Just Dominant Hand and Non-Dominant Hand. Am I missing something?
I did the update and now sync, heart rate, count is not working. I have uninstalled and reinstalled twice, shut off the device and restarted twice, turned off blue tooth several times. How do I resolve this? I have tried for several hours And I got it to sync once and it hasn't since.
I had the same problem.  I found the setting on the device in the settings area.  It is where the battery indicator, Notifications settings and Screen Wake options are.  Just swipe up on the device.  It is at the bottom of the list.
Were you able to figure this out? I’m having the same issue.
Well, we figured out it's working as designed! There's no way to select just some of those stats.
I went over to this thread and added my opinion: https://community.fitbit.com/t5/Feature-Suggestions/Weight-notifications-on-Inspire-HR-device/idi-p/...
You could do that as well. I think it might make a difference if lots of people want this changed.
Hi all! Just wanted to take this opportunity to thank you all for your feedback on Inspire & Inspire HR firmware version 1.57.15. Your feedback was integral to the success of this build!
I am also happy to announce that we have released a new firmware version (1.60.39)! As a result, I will be closing this thread to further comments.
If you have received a new prompt to update your firmware, you can find step by step instructions on how to do so by checking out my lead post, here
If you have additional questions related to firmware updates, feel free to post in the thread above.
Thanks again, everyone. Keep on stepping! 👟
