08-31-2020 09:03
08-31-2020 09:03
Purchased the Inspire and the clip. Wore to grocery store this morning and when I returned the fitbit showed 3,591 steps and my Samsung watch shows 1,985 steps. I believe the steps on my watch are accurate, so the fitbit is wildly overstated. The clip is attached to my bra. I did check my stride setting and it is accurate. Is there something I can do to get a more accurate step count?
08-31-2020 12:32 - edited 09-05-2020 07:44
Hello @SunsetRunner and welcome to the help forums. Do Samsung watches reliably count steps when you push a shopping cart? Many wrist worn trackers, including Fitbits, depend on the arm swing while walking to count steps. If a Samsung watch behaves like this, it will undercount steps when you are pushing a shopping cart. Can you do a comparison where you are walking normally (not pushing a cart)? Is there still such a big difference? Also, verify that you have your Inspire on the On Clip setting and not the On Wrist setting.
Laurie | Maryland
Laurie | Maryland
08-31-2020 13:09
08-31-2020 13:09
09-01-2020 04:37
09-01-2020 04:37
@SunsetRunner It doesn't matter if you have the clip on your bra or on your hip. Fitbit says both sites are fine. IMHO, you are less likely to send your Inspire through the wash if you wear it on your bra. Fitbit made three models of clip on trackers before releasing a wrist tracker. Many of them met an untimely demise in the laundry, left in a pocket. 😉
Laurie | Maryland
