08-31-2019 06:00
08-31-2019 06:00
Since I received the new dashboard my band is not showing any progress through the day at all.
08-31-2019 07:47
08-31-2019 07:47
The title of your post sounds like your problem is you only have 2 fields showing.
But the actual post sounds like you data is not changing during the day.
What really is the issue?
Best Answer08-31-2019 08:06
08-31-2019 08:06
Best Answer08-31-2019 08:40
08-31-2019 08:40
The phone app update should not have had any effect on the actual tracker. Try doing a restart to see if that will let you swipe again:
Also you might want to try a different clock face on the tracker. I use 'Stats Heavy' which shows time, steps, heart rate, calories, and distance all on the main screen with no swiping, though in smaller print.
See How do I change the clock face on my Fitbit device?
Best Answer09-05-2019 14:55
09-05-2019 14:55
The problem resolved itself. Thanks for your reply though, I will keep it for future.
Best Answer09-05-2019 16:37
09-05-2019 16:37
Hello!
I'm having this same problem. I updated my Fitbit App a couple days ago. Now, my fitbit only shows the time and I can't tap or swipe the face to show any thing else but the time and calories burned. When I go into the app on my laptop, it says that my bluetooth is not on, but bluetooth is on on my phone. The app on my phone and laptop are syncing to my fitbit. When I hold the button down, it just vibrates, but does nothing.
I tried this solution, but did not work. Looking for some advice on how to resolve this issue. Thanks in advance.
Best Answer09-05-2019 16:48
09-05-2019 16:48
Ok, I just played around with the clock faces and it worked! Thank you so much!
