12-11-2020 20:21
12-11-2020 20:21
Inspire broken at point band attaches; band won't attach. In another forum I saw that others had the same problem. It's not the band, it's that the band won't stay attached because a tiny piece of plastic broke off the Inspire.
06-28-2022 08:34
06-28-2022 08:34
Best Answer07-18-2022 08:04
07-18-2022 08:04
Mine just broke. I will be buying an Apple.
Best Answer07-18-2022 08:06
07-18-2022 08:06
I just tried to super glue it. I hope it works. I thought it was a terrible design when I first got it.
07-18-2022 08:07
07-18-2022 08:07
I just tried to super glue it. If it doesn’t work, I am getting an Apple Watch.
Best Answer08-03-2022 06:49
08-03-2022 06:49
Mine broke like yours. With nothing too lose, husband used a 1/16 drill bit and drilled a hole angled slightly inward through the indented place for band spring. He removed the band spring, ran a piece of heavy fishing line through it the ran line through the holes. Using two pair of tweezers he pulled the line tied it and heated the ends to form a knot that doesn't slip. I used it for a month, before buying a new one. It's still attached.
Best Answer08-03-2022 12:07
08-03-2022 12:07
Best Answer08-04-2022 02:53
08-04-2022 02:53
Hi, I have the same issue with my Fitbit inspire, it just happened today and the strap will no longer stay attached and I cannot wear it. My inspire was purchased in February 2021. Can you please ask someone to con me to offer help?
many thanks Amberjane.
Best Answer08-04-2022 08:50
08-04-2022 08:50
Best Answer08-12-2022 21:07
08-12-2022 21:07
The same thing happened to me with my inspire hr that I got Christmas of 2020. I have been trying to see if I can swap the face over as I have the band's but I can't find any information to help me
Best Answer08-13-2022 05:08
08-13-2022 05:08
This is what I got from Amazon: Kakurookie 2 Pack Compatible with Fitbit Luxe/Inspire/Inspire HR/Inspir... https://a.co/d/gqB7uUF
Best Answer08-15-2022 13:27
08-15-2022 13:27
I had the same issue. Purchased in January 2020, and it broke in August 2022. Very frustrating to buy a new tracker when the device itself works fine. I tried the fitbit chat with support but they had no solution or discount offer to purchase new. I'm planning to super glue and see how that holds.
Best Answer08-15-2022 14:24
08-15-2022 14:24
Best Answer08-20-2022 15:35
08-20-2022 15:35
I’m experiencing that now where one side of my inspire 2 band won’t stay in. I’m trying to find support.
Best Answer08-20-2022 16:53
08-20-2022 16:53
Best Answer08-20-2022 16:54
08-20-2022 16:54
Best Answer08-21-2022 10:41
08-21-2022 10:41
My Fitbit inspire HR broke right after the warranty expired. I can't attach the bands any longer. It is unfortunate as Fitbit’s digital part works perfectly (so far). Bad design and cheap materials...
Thanks for the link for an alternate idea to save the main part. Would Inspire HR fit in these bands?
Best Answer08-21-2022 19:46
08-21-2022 19:46
10-23-2022 19:32
10-23-2022 19:32
Hi there -- I have the same problem. I took it to a jeweler to get a replacement watch band put on because I didn't realize the problem is that the casing of the fitbit is broken -- it's the exactly same as Jacky Y's pic below. Can I just get the case that goes around the device? Now I have a new band and I can't use it because there's nothing to attach it to. So frustrating! Thanks for whatever help or suggestions you can offer.
Best Answer10-24-2022 06:41
10-24-2022 06:41
Best Answer10-24-2022 09:07
10-24-2022 09:07
Thank you! I don't want a whole new band though -- I just need the casing around the fitbit so that I can attach the replacement band I bought. I don't know if that's even a thing that exists though...
