03-25-2019 19:22
03-25-2019 19:22
I just purchased the Inspire and can't figure out how to change the clock face. It only lets me adjust to a 12 or 24 hour clock.
08-20-2020 18:42
08-20-2020 18:42
Mine won't connect either. The clock face page stays white with green circle spinning to no avail.
I've tried restarting the app and the watch and resyncing it too. Still will not change clock face. What else should I try?
Best Answer08-21-2020 04:45
08-21-2020 04:45
Best Answer08-21-2020 14:33
08-21-2020 14:33
I am using a desktop computer and I downloaded the app.
Best Answer09-03-2020 19:18
09-03-2020 19:18
I am having this exact issue. I haven't found a solution yet.
Best Answer09-03-2020 19:56
09-03-2020 19:56
Update.
Apparently the issue with the white screen and neverending green spinner is known, and it is cause by the version of android not being new enough. All of my devices are running 6.0.1. Apparently, you need Android 7 or higher. There is no solution.
Best Answer09-04-2020 07:28
09-04-2020 07:28
You can install the Fitbit app on a Windows PC to do the upgrade. The PC will need Bluetooth or a Fitbit dongle. WIndows 10 recommended and the app is in the Windows Store. Many laptops have Bluetooth.
Best Answer09-04-2020 08:11 - last edited on 10-14-2020 20:55 by LiliyaFitbit
I have tried this as well. I chatted with another agent just now who has
informed me that Windows 10 is no longer supported on the InspireHR as of
the latest firmware update. HOWEVER, my mother and I both purchased these
same devices yesterday, and we are using the same technology to interact
with them. Her device works, and mine doesn't. So, the agent said they will
replace the device.
Best Answer09-04-2020 08:19
09-04-2020 08:19
Best Answer09-04-2020 08:29
09-04-2020 08:29
Windows 10 not supported? That is not good! Not everyone who uses a Fitbit has a cell phone, tablet or other mobile device. My wife for one who still uses a Fitbit ZIp and sync's it with her Windows 10 desktop.
Will have to try the app on my laptop with the inspire HR, Sure wish there was a Fitbit app for Linux...
Best Answer09-07-2020 13:03
09-07-2020 13:03
Thank you! I hadn't had this issue at first but after a recent app update and firmware update it started, your solution sorted it for me, I never suspected my ad blocker!
Best Answer10-13-2020 22:24
10-13-2020 22:24
I can't find clock. Or how to sync.
Best Answer10-20-2020 07:49
10-20-2020 07:49
Thank you, after days of trying to do this, it took less than 3 mins!
Best Answer02-14-2021 05:30
02-14-2021 05:30
Same problem here. "Clock face" tile appears but no options appear when selected, just a blank page. Using Inspire HR and iPad.
