07-25-2019
21:07
14:29
YojanaFitbit
07-25-2019
21:07
14:29
YojanaFitbit
I just got my new inspire hr today and while going through set up process when I got to the portion where it said it needed an update I am now stuck. It either wants me to plug up my Fitbit while it's on the charger or flat out refuses to connect. all my Fitbit shows is the bar like it's updating but it's not and I can't do a soft reset. someone please help
07-26-2019 13:56
07-26-2019 13:56
Having same issue. And charger will not stay connected. Weak magnet?
07-26-2019 14:28 - edited 01-01-2020 11:07
Nice to see that you're digging into the Forums @Jlee5397 and @mrsmustache, let me give you a warm welcome to our Community.
Thanks for sharing the details of what is happening when you're trying to update your new Fitbit Inspire HR.
Thanks for trying to restart your Inspire. But since this was stuck while finishing the update, it's best if you plug in into the charger and try to finish the update. Please make sure that your phone and Fitbit app are up to date. And confirm that your phone is connected to strong internet connection.
You can also try the following steps:
This should solve any syncing issue that you're having, please keep me posted on the resolution!
