09-08-2019 06:41
09-08-2019 06:41
If I press the button, it vibrates like its on, but the display is black. No time display, no nothing. It's attatched to the charger cable so it's not out of juice.
Best Answer09-08-2019 19:04
09-08-2019 19:04
This same thing happened to me. I contacted fitbit support; they had me put my Aspire on the charger and hold down the button for about 15 seconds. I had to do this twice and it worked. It's like it gave it a jump start. Hope this helps you too.
09-08-2019 19:04
09-08-2019 19:04
10-07-2019 07:55
10-07-2019 07:55
Same thing happened to me, thanks for solving it for me. Worked while on charge and pressing the button for 15 seconds.
01-13-2020 06:32
01-13-2020 06:32
Thank you so much! It worked for me too.
02-04-2020 07:02
02-04-2020 07:02
Display on screen is not showing anything
02-05-2020 04:41
02-05-2020 04:41
👍thanks!worked for me
Best Answer02-05-2020 06:06
02-05-2020 06:06
This happened with my fitbit inspire. I read your comment so I followed it. I charged it then pressed down the button for 15 secs. Just when a smiley came on the screen then I let go off the button. It worked! Thank you very much!
02-05-2020 07:42
02-05-2020 07:42
You're welcome, I got the answer from this as well,
Best Answer02-05-2020 10:52
02-05-2020 10:52
Same issue with mine today. It's the first problem since purchasing the Fitbit in January, but the 15 second reset seems to have worked.
Best Answer08-20-2020 12:03
08-20-2020 12:03
I received my new Inspire HR. I charged it. I plugged the charging cable into my computer. I held the button for 15 sec and got a smiley face. I let go. My phone found the fitbit and the tracker displayed a 4 digit code. I entered the code on my phone. I got a checkmark on my tracker. Then tracker went blank with only a faint horizontal line across the screen. Nothing else displays, I cannot scroll in any direction. My app says the tracker synced 1 min ago, shows it is fully charged. Just that horizontal line on the tracker screen.
I contacted Fitbit and they determined it wasn't working so they sent me a new tracker. Same exact thing happens. I contacted Fitbit and they say that it is an unexpected error. I have to send the tracker back and they will send out a new one. 0/2 seems like a very high fail rate.
We tried deleting and setting up new tracker several times on each tracker.
Anyone else have this type of error?
08-20-2020 13:47
08-20-2020 13:47
Sorry i cant help, hopefully someone on here will help you, good luck
Best Answer08-20-2020 19:24
08-20-2020 19:24
Hi my inspire Fitbit display is not working. The Fitbit is working otherwise. I tried to plug it into the charger and press and hold the button for 15 seconds as recommended ( more than once!) and this did nothing:(. Any advice?
08-21-2020 00:59
08-21-2020 00:59
I,m very surprised that doesn't work for you, as it has for me many times. There must be another issue with yours.
Best Answer08-21-2020 04:46
08-21-2020 04:46
Best Answer08-21-2020 08:29
08-21-2020 08:29
Do you have a phone number for Fitbit support? My inspire face is blank and still not working after rebooting several times whilst in charge. Thanks
08-21-2020 10:08
08-21-2020 10:08
I got this on my fitbit app, 0800 069 8505 mon-fri, 8.00am - 7.00pm.
08-21-2020 13:12
08-21-2020 13:12
Many thanks
Best Answer08-22-2020 10:19
08-22-2020 10:19
Well, mine is doing the same thing so I have to contact them?
Best Answer08-22-2020 12:09
08-22-2020 12:09
that doesn't inspire me with confidence. I just ordered a pair for myself and my daughter. the one I just tried to set up done the same as yours 😞
Best Answer08-22-2020 13:17
08-22-2020 13:17
no display on my fitbit
