04-13-2019 08:31
04-13-2019 08:31
Every once in a while the face gets stuck on “finish”. This is sometimes after exercising, other times not. Seems pretty random. Gets stuck, then after awhile returns to normal, only to get stuck again. Ideas?
04-13-2019 09:52
04-13-2019 09:52
Can you explain the finish" more? Does that word come up on your screen other than after exercising?
04-13-2019 10:10
04-13-2019 10:10
07-06-2019 08:07
07-06-2019 08:07
Does anyone know a way out of this? I see no answer from the company and I'm having the same problem. One solution in another thread said to reset the clock. That works but I truly hope they find a real fix for the problem, like a way to cancel the exercise altogether.
07-17-2019 14:37
07-17-2019 14:37
Ok so this happened to me today and this is how I got out of it:
-Tap on the “Finish” icon
-“nice work” should appear and then scroll all the way down until you see “Close [x]” and tap on that icon
-this then leads you back to “exercise” and you can scroll back to your clock face.
hope this works for you!
07-19-2019 19:40
07-19-2019 19:40
Thank you so much for this information! I was pulling my hair out trying to figure this out and your instructions fixed my problem!
08-26-2019 09:03
08-26-2019 09:03
That worked! Thank you!
12-03-2019 10:05
12-03-2019 10:05
Thank you soooo much Roxy Marie! You have saved my sanity! Perhaps you should write the manual for using this fitness tracker!
01-15-2020 17:39
01-15-2020 17:39
Pretty lame. Hope they fix this soon. Not what you would expect from a name brand.
05-25-2020 17:45
05-25-2020 17:45
Fabulous. I was very frustrated and that worked! Thanks
09-07-2020 09:08
09-07-2020 09:08
Am keeping this thread and the SOLUTION active, since i too have started having the same problem in the last few weeks (have had my Inspire for over a year).
THANK YOU Roxie for a solution; i have copied it here for others to easily find!!
