11-28-2019
19:31
07:43
11-28-2019
19:31
07:43
I've just bought an Inspire, connected to Android phone but the screen only shows the fitbit image and www.....set up no swiping or pressing the button on the left seems to engage it. Help for a beginner much appreciated!!
11-29-2019 07:49 - edited 11-29-2019 07:51
Hi there @HeloiseB, welcome to the Community Forums. Thanks for the details provided, I'll be more than glad to help you.
In order to solve what you're getting on the screen, please try doing the following:
Last but not least, I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
I've moved your post to the Inspire & Inspire HR board as there are more chances to get related replies here.
Let me know if this solves your issue, I'll be around if you need further assistance.
07-06-2020 05:13
07-06-2020 05:13
Hi I'm still encountering this problem. The instructions didn't seem to work for me.
I have a Huawei P10 Lite (the P10 is listed in the compatible phones list, but not the Lite. Is it compatible?)
Thanks
07-06-2020 09:29
07-06-2020 09:29
I tried everything in your answer, except I could not find out how to update the app. My phone is a Samsung Galaxy J4+. I checked the list of phones compatible and the J3 is there, so presumably the J4 is a later model. Is it supported? Is that why I am having difficulty? The Inspire HR just does not work if I tap it. I have to press the switch at the side and all I get is www.fitbit.com/setup.
Have been trying all afternoon and getting really fed up now.
07-24-2020 05:15
07-24-2020 05:15
I'm experiencing the same issue; however, I have a Samsung S8.
I'd appreciate any advice on how to sync the devices.
Thanks.
07-24-2020 11:21
07-24-2020 11:21
08-05-2020 21:07
08-05-2020 21:07
For some reason I couldn't move beyond the screen that says "make sure your device is on". But this did finally work for me.I was unable to locate the firmware part so I skipped it and it's FINALLY syncing.
I was ready to take this back to Best Buy and get a Garmin!!
Thank you for your help!
08-10-2020 08:23
08-10-2020 08:23
Is this information applicable to those of us using a desktop computer or is it just for the phone.?
08-10-2020 08:31
08-10-2020 08:31
08-10-2020 20:16
08-10-2020 20:16
I also had to empty cache and settings thru' apps on my phone ( for me it was in my storage card memory thru settings on phone) This worked. I also did other directions previous to this.
08-11-2020 11:22
08-11-2020 11:22
08-11-2020 13:45
08-11-2020 13:45
I am also using it on a desktop computer and having the same issue ... what can I do to get this to work for me? (I am very frustrated!)
08-11-2020 14:04
08-11-2020 14:04
