12-25-2020
01:32
04:07
JuanJoFitbit
12-25-2020
01:32
04:07
JuanJoFitbit
I've just set up my device and it doesn't stop doing things on its own. It scrolls up and down randomly. I looked at it a minute ago and it had opened a timer and was setting one on its own.
I have set the wrist setting. Tried swapping it to my dominant hand, but this makes no difference.
Does anyone know how I can fix this issue?
Moderator edit: format
12-28-2020 04:07
12-28-2020 04:07
Hi @Squeak13, welcome to our Fitbit Community. I appreciate the time spent trying to get this issue resolved before contacting our forums.
Please restart your Fitbit Inspire as described in this help article. After this, monitor it during the next 24 hours and see if it stops scrolling and opening apps on its own.
Keep me posted on the outcome.
12-29-2020 01:59
12-29-2020 01:59
Hi, we are having the same issue, have tried over a dozen restarts, 100% battery, 0% battery. Nothing is making a difference. It seems the screen is getting touch signals and scrolling or selecting constantly. Brand new device. I am very interested in any solution.
12-29-2020 02:34
12-29-2020 02:34
Restarting the device made no difference. I ended up taking it back to where it was purchased and getting a replacement. Haven't had any issues with the new one
12-29-2020 02:36
12-29-2020 02:36
I was joking that mine was possessed xD it's odd isn't it?
Ended up going back to the store and exchanging it. No problems with the new device
