09-06-2019 16:28
09-06-2019 16:28
Silent alarms did not go off this morning, when I went to see if they had inadvertently been turned off noticed it had not synced since Aug 22nd. Have tried all day to sync to mo avail. Uninstalled, reinstalled app, nothing, wifi off, wifi on, nothing. Phone charged, Fitbit charged, nothing, at a complete loss as to why it won't sync and alarms stopped.
Help?
09-06-2019 19:30
09-06-2019 19:30
Hi @MelInTx What phone are you using? Is it on the Supported Devices List?
Try all the suggestions in THIS Help Article on Syncing Problems
Helen | Western Australia
09-06-2019 19:53
09-06-2019 19:53
Best Answer09-07-2019 02:28
09-07-2019 02:28
Yes, there seems to be a Fitbit problem at the moment, so I guess try again tomorrow.
09-07-2019 15:45
09-07-2019 15:45
My Inspire HR is doing the same thing. It stopped syncing August 22. I have uninstalled, reinstalled, even got a new phone and installed a new app to that and it still won't sync. I have been trying to sync for a week plus.
09-07-2019 17:03
09-07-2019 17:03
@CShell1964 What phone are you using?
09-07-2019 18:14
09-07-2019 18:14
Best Answer09-07-2019 18:21
09-07-2019 18:21
Hi @CShell1964 That one should work. Try all the suggestions in the Help Article I linked above, but come back if you continue to have problems.
09-08-2019 14:22
09-08-2019 14:22
Mine also doesn't sync for silent alarms - Huawei P10 plus.
Also notifications don't work. It says: "Notification service not running. A phone restart is required to re-enable notifications on your tracker" Restart of the phone or reinstalation of the application doesnt help, keep see the same message.
Best Answer09-08-2019 17:14
09-08-2019 17:14
Hi @Elcia I think your is a phone compatability problem as your phone is not on the Supported Devices List
All you can do is try all the suggestions in there Help Articles
WHY WONT MY TRACKER SYNC
https://help.fitbit.com/articles/en_US/Help_article/1866
TROUBLESHOOTING NOTIFICATIONS
https://help.fitbit.com/articles/en_US/Help_article/1610
09-09-2019 10:51
09-09-2019 10:51
Mine has not worked at all since the August 15th update to the app. Started with my silent alarm not working, then the sleep wasn't getting tracked. I restarted the device over 50 times, deleted and reinstalled the app (including a week long waiting period in between the uninstall and reinstall) countless times, have restarted my phone, turned on and off WiFi, turned on and off Bluetooth, checked my phone for device updates, made sure it is on the compatibly list, even "forgot" the fitbit from my phones previously connected devices. it will show up in the available devices but it will not reconnect. I'm about to just throw mine in the trash because i'm so over it. P.S. Its not even a year old. This is the Inspire HR.
Best Answer09-09-2019 13:51
09-09-2019 13:51
I have a Samsung Galaxy 7 and mine stopped syncing last week as well. It was fine for 2 months from when I first got it until now. What gives? Why would it work for 2 months and then suddently stop?
09-10-2019 04:37
09-10-2019 04:37
Well I finally got my phone to connect, I had to make a completely new account.
Best Answer09-10-2019 14:23
09-10-2019 14:23
I'm getting the same notification problem I turned my phone on and off and still nothing been happening for like 2 weeks
Best Answer09-11-2019 11:57 - edited 01-01-2020 10:50
Hi everybody nice to see you here. Welcome to our new users. Thanks @NellyG for all the steps that you've suggested here. My apologies for the delay.
I really appreciate the time you've taken to help your Fitbit Inspire to connect again. You can also check the following steps to troubleshoot if the syncing issue persist:
Requirements for a successful synchronization:
If the syncing issue remains, I would recommend following the steps below:
You will find more syncing steps here.
This should solve any syncing issue that you're having, please keep me posted on the resolution!
Best Answer09-16-2019 07:46
09-16-2019 07:46
It started to work now again.
I am unsure why it would not be compatibile. I had fitbit 2 HR before and everything worked ok, then I got myself a new fitbit inspire HR and worked ok until fitbit started to mess up their app updates. Also it looks like I'm not the only one as many people is complaining that after each app update something doesn't work as it should. So maybe fit bit should look in this direction more.
