02-15-2021
13:17
03:22
AlvaroFitbit
02-15-2021
13:17
03:22
AlvaroFitbit
I have traveled back in December and my watch set to the time zone I was in, now I still can't get it back to my time zone at home. I have tried syncing it a dozen times, turned it off, checked for updates...nothing works and it's an hour off. This is so frustrating
02-16-2021 03:29
02-16-2021 03:29
@tanyam101 Thanks for being part of our Community!
Let me help you with this and thank you for troubleshooting this issue. I suggest you manually change the timezone to a completely different one, save and sync, then change it back to the correct one, save and sync again. You may also restart your tracker.
Hope this helps.
