11-17-2019
06:16
07:12
AlejandraFitbit
11-17-2019
06:16
07:12
AlejandraFitbit
My screen wont move from the date.just seems to be locked there.
08-07-2020 14:43
08-07-2020 14:43
Hi! I plugged it in and held the button down for 5 seconds at a time like 4 or 5 times, and then pressed it quickly like 5 more times, and then it reset. No idea which part worked! 🙂
Best Answer08-07-2020 14:53
08-07-2020 14:53
Best Answer08-08-2020 08:50
08-08-2020 08:50
This helped me so much. Thank you. I have no idea why the screen goes blank every time. I always have to go into the app to track my progress. Isn't there a way Fitbit can see the issues and resolve it? I see so many reviews with the same issues and it just seems its an ongoing issue that needs to be recalled.
10-05-2020 08:54
10-05-2020 08:54
Thanks I tried this today and it worked.
Best Answer08-22-2021 11:49
08-22-2021 11:49
Yes I had the similar problems mine won’t go up or down
Best Answer05-04-2022 07:49
05-04-2022 07:49
Have you figured it out? I restarted mine 5 times and no change in the screen
Best Answer05-04-2022 16:29
05-04-2022 16:29
Best Answer08-07-2022 15:19
08-07-2022 15:19
No buttons
