11-17-2019
06:16
07:12
AlejandraFitbit
11-17-2019
06:16
07:12
AlejandraFitbit
My screen wont move from the date.just seems to be locked there.
05-14-2020 08:56
05-14-2020 08:56
05-14-2020 09:33
05-14-2020 09:33
05-15-2020 07:57
05-15-2020 07:57
Thanks for the advice,worked first time. Fitbit was stuck on calorie screen.
05-15-2020 11:48
05-15-2020 11:48
Until recently, when my inspire HR froze up simply changing the clock screen unfroze the device. (I love the cat face, but it seems to be the one that freezes) you might try that. Now my app won't even let me change the clock face. Will try restarting the device.
05-26-2020 06:21
05-26-2020 06:21
hello! This is affecting my inspire as well. I have restarted it and I do get the smiley face, but it does not vibrate and remains frozen.
05-26-2020 13:29
05-26-2020 13:29
05-26-2020 19:45
05-26-2020 19:45
I tried this several times and like others have said it vibrates a little but never changes.. It won't scroll or show any other screen or switch to check the battery status. Disappointing as only have had it 5 months.
05-26-2020 23:20
05-26-2020 23:20
I restarted my Inspire HR and saw the smile three times No change to the display. It’s still stuck on the time. Help!
05-27-2020 00:42
05-27-2020 00:42
05-27-2020 01:48
05-27-2020 01:48
06-20-2020 12:36
06-20-2020 12:36
It worked! Back in action.
06-29-2020 04:27
06-29-2020 04:27
Hi all,
Had the same problem -and plugging in and powering down didn't work. What did work was changing the clock face. Go into your Fitbit app, select clock face designs, and choose another design. This prompted my Fitbit to respond. I then changed my clock face back to my preference. Works fine again. The freezing seems to happen after I charge my Fitbit. This is a glitch that needs to be addressed.
06-30-2020 19:55
06-30-2020 19:55
My inspire was stuck on one screen also! Why worked best to fix it was to:
1.go to the Fitbit app
2. Tap the top of your screen where it lists your device
3. Change the clock face
Once I changed my clock face to a random one and then changed it back to my original one it finally was unfrozen! Hope this helps because I was also unable to restart my inspire!
06-30-2020 20:53
06-30-2020 20:53
07-01-2020 03:34
07-01-2020 03:34
07-09-2020 04:58
07-09-2020 04:58
My inspire HR is frozen and won’t change screens, I’ve tried restarting several times and it is still frozen. What do I do now?
07-09-2020 06:16
07-09-2020 06:16
You might try going into your inspires settings and changing the clock face. If you are not having any internet problems this should correct the problem. However, this is not a permanent fix. I have had my inspire since December and my screen has frozen up about once every 6 weeks.
07-09-2020 07:17
07-09-2020 07:17
Thank you for your response. I have tried your suggestion and it is still frozen. I’m ready to go back to my Garmin tracker, I never had these issues. The only reason I bought the Fitbit instead of another Garmin device was the band style,
07-09-2020 07:34 - edited 07-09-2020 07:38
I'm having this issue to but it's been stuck on the active minutes screen instead (after resetting multiple times). I'm really not happy...I was having issues with sleep tracking and auto-tracking work outs, and when I reached out to fitbit in May they kept telling me to do the troubleshooting steps that I had already taken. Those issues were never resolved, and I just gave up because no one was offering any help besides telling me to do the things I started I had already done.
Edit: Just got an email from FitBit saying that my device is still under warranty and I can get a replacement. Highly recommend reaching out to the directly too for some extra help!
07-09-2020 07:48
07-09-2020 07:48
Thanks for your response. I will reach out to them as I have had my Fitbit since December 2019. I am concerned so many people are having this exact issue.
