03-24-2024
14:16
07:38
03-24-2024
14:16
07:38
When I’m outdoors. And it is sunny and bright. I am not able to see the display on my inspire. Is there a way to brighten the display screen ?
03-26-2024 07:45
03-26-2024 07:45
Hi there, @Pinoalberga. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Inspire. I understand where your concern is coming from. I will do my best to help you with this!
Please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
04-03-2024 03:34
04-03-2024 03:34
This does not work.
I own two Fitbit Inspire 2 and one of them has the screen so dim that I can't even see indoors. I have to be in a very pitch black room to see the screen. I have contacted warranty and they say that warranty does not apply for this issue. This is a manufacturing issue that should be covered by Fitbit/Google, but no.
04-03-2024 09:55
04-03-2024 09:55
I have the same issue. Screen light is so dim, can't see display in a daylight. I followed the instructions given by tech support, but still can't fix the problem.
04-22-2024 06:42
04-22-2024 06:42
Same can only see Fitbit screen in darkness... not very useful really.
Has anyone managed to solve this problem and if so can they share their tips?
BTW Fitbit, don't advice restarts and changes to clock faces, it doesn't work. I have been back to factory setting, out of the box.
