02-22-2020 16:22
02-22-2020 16:22
Woke up to my silent alarm and couldn’t turn it off because my side button wasn’t working. Eventually it stopped. Then I realized that I couldn’t turn the screen on or off using the side button. It only works with movement to look at the face. If I hold down the button, it will vibrate, but the screen will not change from clock and steps to the battery life. The touch screen will not work at all. When I get the movement notification, it only vibrates. Nothing shows up on my screen. It just stays black. I can’t find any answers in troubleshooting or while scrolling thru the forum. I tried to live chat, and that was an absolute joke. It closed out on me while I was trying to type my problem out and told me I was done and asked me to do a survey. When I tried again, I was chatting for a minute and after they asked for my email, it closed out again telling me I was done. Extremely frustrating! I haven’t been happy with Fitbit at all so far and I’ve only had it since January 24th. Does anyone have any suggestions?
02-22-2020 16:30
02-22-2020 16:30
Hi @Branles That sounds pretty frustrating! Try restarting the tracker several times and see if that fixes it. If it doesnt you will have to go back to Support Im afraid. Maybe try a different method to contact them?
Helen | Western Australia
02-22-2020 16:30
02-22-2020 16:30
02-22-2020 16:34
02-22-2020 16:34
Best Answer02-22-2020 16:43
02-22-2020 16:43
OMG... thank you so much!!! It worked! You are my hero. Good thing for the community, because Fitbit was no help.
Best Answer02-22-2020 16:47
02-22-2020 16:47
No, a restart wont lose you your steps, but you have already tried it! So glad it worked 👍
Best Answer02-23-2020 14:39
02-23-2020 14:39
I am having this same issue. How do I restart the device? Thanks!
Best Answer02-23-2020 17:56
02-23-2020 17:56
@kimmie.d The link is in my first post in this thread. Tap on the blue link and follow the instructions for your tracker.
Best Answer02-23-2020 17:57
02-23-2020 17:57
