07-14-2022
01:25
17:17
07-14-2022
01:25
17:17
My Inspire will not record sleep properly since update a week ago. Can I remove update? I use it for sleep data due to chronic illness. Any suggestions?
07-14-2022 17:22 - edited 04-18-2024 11:41
Hi there, @SleeplessinSA. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire.
As a first approach, I'd recommend trying the following steps to make sure your heart rate is working as sleep stages are based on heart rate readings:
Also, for more detailed information, see What factors can affect my heart-rate reading on my Fitbit device?
In addition, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Best Answer07-15-2022 23:28
07-15-2022 23:28
07-17-2022 08:13 - edited 04-18-2024 11:40
@SleeplessinSA Thanks for the update.
I'll be around if you need further help. Have a nice day! 🙂
Best Answer07-17-2022 17:57
07-17-2022 17:57
07-21-2022 20:59
07-21-2022 20:59
Hi @MarreFitbit I did all the steps twice or thrice ,reinstall app 3 times restarted mobile ,fitbit ,re set the device on my mobile by removing and adding fitbit again but still it is not showing both sleep data and heart statistics also.also spoken on fitbit chat. But it has stopped showing both data Since 18/07/2022 any idea what to do ?
07-22-2022 02:13
07-22-2022 02:13
Best Answer07-22-2022 03:52
07-22-2022 03:52
I did it several times but no luck thanks for reply
07-27-2022 10:04
07-27-2022 10:04
Is the factory setting reboot still working for you? I have been struggling with sleep setting consistency for months now with no solution. Wondering if this has helped and if you lost all of your data when resetting? Thank you!!
Best Answer07-27-2022 15:01
07-27-2022 15:01
Best Answer07-28-2022 01:46
07-28-2022 01:46
Same with me . I lost the data but still no luck ..even the heart beat is showing very high .I also did what ever recommended in community but not luck . Heart rate it's showing while resting us 165 and above . And it's continuous activity mode. Even though not doing any activity. I tried negating activity by entering driving data. Have to keep doing it.. so it seems that something is completely wrong with my Inspire HR. I had spoken to a chat agent he told me that heart rate algorithm has changed ...hope I get some help with my Inspire HR Fitbit.
Best Answer07-28-2022 05:22
07-28-2022 05:22
