09-19-2023 11:24
09-19-2023 11:24
My inspire has stopped tracking any sleep data aswell as my auto exercise on the same date. I know i have tried to remove redundant apps and settings but don't know if it bas effected this at all. It still records my steps and when i excerise adds them to my steps but nothing else.
I have checked, location services are on for fitbit app, rebooted the watch and signed into the app again, turned the auto setting off and on, unpaired bluetooth and repaired.
What is needed to be on and installed to be able to do this?
Please help it's driving me mad!
09-19-2023 12:04
09-19-2023 12:04
Welcome to the forums @Taz1000.
Thank you for sharing the inquiry regarding your Inspire and for trying to fix it by your own. I'm sorry to know about this inconvenience that you are experiencing.
Please, keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
Even if you already tried a restart, please try to do that one more time, following this steps. Try adjusting the sleep sensitivity on the Fitbit app and check if you continue to have the same problem.
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
Best Answer09-19-2023 21:53
09-19-2023 21:53
I have done all of these things. It has not worked since July 1st. I'm so disappointed as I have owned fitbits for over a decade and suddenly with this switch to Google, nothing works.
09-20-2023 05:07
09-20-2023 05:07
Welcome to the community @Minimarj.
Thank you for sharing with us the inconvenience with your device.
I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
00:17
09:09
ManuFitbit
09-21-2023
00:17
09:09
ManuFitbit
Me too and ditto! Tried everything!
Is there a number for the customer service team please?
09-21-2023
04:28
09:14
ManuFitbit
09-21-2023
04:28
09:14
ManuFitbit
I just did a help chat for the same issues. In quick settings (hold both sides down) scroll to the bottom there is an image of a device. Make sure it says On Wrist and not Clip. I am hoping this works, will find out tonight!
Best Answer09-21-2023 04:49
09-21-2023 04:49
I have done all of that. Changed the mode of sleep. Its always on my non dominant. Its the exercise aswell as sleep though and I know I can manually add but not as accurate or easy.
