Inspire stopped tracking sleep
I'm happy that Inspire tracks my pool walking and seems to be accurate, but it stopped tracking my sleep,??? Both are important to me.
4 REPLIES 4
Hi @TrixieOutWest - This just started randomly? I'd definitely start with restarting the tracker. Follow the directions in the link below.
https://help.fitbit.com/articles/en_US/Help_article/1186
Let me know if that helps (or doesn't).
A warm welcome to our community @TrixieOutWest I'll be happy to assist you with your sleep tracking inquiry.
Since your Inspire isn't registering your sleep, I recommend trying the following:
  1. Manually sync the tracker. See instructions in How do Fitbit devices sync their data?
  2. As @Ozzie65  mentioned, restart the tracker. See instructions in How do I restart my Fitbit device?
  3. Try sleeping with the tracker on your non-dominant hand.
  4. If steps 1-3 don't work, I suggest manually logging your sleep to reflect the time slept. See instructions in How do I change my sleep history?
Thank you for your assistance @Ozzie65.
Keep on visiting the forums.
I tried this several times, and no results. Since it stopped tracking a couple of weeks after I started using the fitbit in the water to track steps in the pool (which works great!), I wonder if that's the cause.  Thanks for your assistance, though..
Hi! Manual sync and restart did not work. I wonder if it stopped because I'm using the Fitbit in the pool to track steps now. It was around the same time. Thanks for your response.
