Inspire time won't update after traveling
ANSWERED
Have Synced fitbit but still an hour out. What can I do.
1 BEST ANSWER
Accepted Solutions
Hi there, @Kevwest. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Inspire.
Note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
I've moved your post to the Inspire & Inspire HR board for organization purposes.
1 REPLY 1
