08-20-2022
16:04
21:04
08-20-2022
16:04
21:04
My inspire two has stopped picking up my zone minutes and my exercise, and yes it’s set to on wrist and the heart zone is on
08-20-2022 17:11 - edited 08-20-2022 17:13
Hello @Randomman
I believe I can certainly help. When Inspire 2 is set to On Clip , certain features are turned off, including heart-rate tracking, automatic exercise tracking, and Active Zone Minutes.
You may have accidentally turned “on clip” mode and it needs to be set to “on wrist” mode to capture your exercise and zone minutes like you want.
Just go to your quick settings and turn it to on wrist mode and you’ll be all set. To get to quick settings just press and hold the button for about 2 seconds on your Inspire 2. This takes you to the Quick Settings. In Quick Settings have your Battery level, Screen Wake, Notifications, and the On Wrist/On Clip setting. Make the switch and press the button lightly to return to the clock face.
😃I hope this did indeed provide you with the best answer for you question. Please let me know.
08-23-2022 05:29
08-23-2022 05:29
@Randomman Did you try restarting your tracker? You can reboot it in the Settings app or by putting it in the charger, then press and hold both buttons for 5 seconds.
08-23-2022 18:36
08-23-2022 18:36
No. Last time you told me that after the last update. I thought…maybe, I could not fix it for over a month. Updated this time and the same exact thing happened.
08-23-2022 19:12
08-23-2022 19:12
Hello @sthompson001
I’m a bit confused about your post. What update? I believe you may have posted your message on the wrong thread.
