05-25-2019 15:04
05-25-2019 15:04
Inspire did track sleep on nite 1 but since not. The icon is dark on the fit bit. How do I turn it on?
11-13-2021 14:48
11-13-2021 14:48
I have the same problem for weeks will get rid of my Fitbit soon it is too frustrating
Best Answer11-13-2021 14:49
11-13-2021 14:49
I followed all the options it worked fir 3 days then stopped again or calculated incorrect sleep time
Best Answer11-14-2021 11:26
11-14-2021 11:26
Last night again incorrect sleep record
i went to sleep at around midnight Fitbit recorded sleep from 2:58am very frustrating
Best Answer11-14-2021 11:30
11-14-2021 11:30
I have tried all the provided suggestions but unfortunately nothing seems to fix the sleep tracking problem
Best Answer11-14-2021 11:36
11-14-2021 11:36
I feel your frustration I am experiencing the same problem on and off since I purchased this inspire Hr I am too very fed up and will be looking at other alternatives
Best Answer11-14-2021 11:41
11-14-2021 11:41
I have the exact problem I don’t believe that the inspire he works it has too many issues especially the sleep tracking
time to switch brands!
11-14-2021 11:42
11-14-2021 11:42
Bin it! It is too unreliable and frustrating
01-02-2023 15:41
01-02-2023 15:41
i move alot in my sleep so it doesnt detect my sleep, what do i do
Best Answer01-22-2023 11:56
01-22-2023 11:56
Somewhere in the settings there is a choice between normal and sensitive. Move it to normal. I just found mine was set to sensitive, which is why it isn’t tracking all of my sleep. The Inspire itself is a **ahem** but hopefully this will restore some of what the company promised it would do. I only care about sleep and steps and too often it doesn’t record the sleep. It also changes settings on its own and you have to fiddle around with it to figure out what it did and undo it. Company won’t admit it’s a lemon.
