08-05-2019 11:52
08-05-2019 11:52
I have had a One fitbit but it died. A week ago I purchased an Inspire with a clip. On my app the Reminder to move Screen is not showing some of the data. It shows the dots of the hours that I reached 250 steps but that is all.
Farther down on the screen where there is “ Longest Stationary Period” and “ All Day Breakdown”. It says No Data and empty bars. Does this happen because I’m using the clip? Or is something not working? I have already found out that the reminder to move notification doesn’t work in the clip. It will be frustrating if the above mentioned doesn’t work either with the clip. Nowhere in any information about the Inspire does it mention certain features don’t work in the clip.
08-06-2019 14:34 - edited 08-12-2019 12:39
Hi @KatMa nice to see you around. Thanks for posting your questions about Fitbit Inspire when using it on the clip.
Sorry to hear that your old Fitbit One died, it was a really good model. You can find all the information about Fitbit Inspire when using it on the clip on the manual pages 10, 12, 13 and 18. Have you tried to restart your Inspire? It should vibrate when it is on the clip too. Make sure your Inspire is up to date. Is your Fitbit vibrating with any other option?
What data is missing from your "Reminders to move" screen? Check if your Fitbit app is up to date too. Then, make sure to force quit the Fitbit app and log out and log back in. Let me know if this helps.
I'll be around.
Best Answer08-06-2019 21:09
08-06-2019 21:09
