03-17-2019 21:15
03-17-2019 21:15
I just got my Fitbit Inspire in the mail and was so excited to set it up, however I cannot to get it to sync to my phone no matter what I do! I have the fitbit and my phone both plugged in. I have tried quitting the app, restarting my phone, and re-connecting to bluetooth. My fitbit is on but won't connect. Help!
12-13-2019 18:35
12-13-2019 18:35
Was trying to connect my new Fitbit Inspire to my iPhone 7, but with no joy. Did all the suggested troubleshooting, still wouldn't connect. I tried chosing Inspire HR instead of the Inspire as the device to connect to, and like a miracle, they are connecting! At 53%!! Will keep you posted!
Best Answer12-25-2019 04:11
12-25-2019 04:11
Thanks for this suggestion. Mine doesn't say anything other than Inspire on it either but after an hour of trying and re-trying I took this suggestion and voila! Now it's connected and updating.
Best Answer12-25-2019 05:25
12-25-2019 05:25
Thank you I read you comment and thought maybe I should try it and it WORKED and no where on the package did it say it was an HR
Best Answer12-25-2019 08:16
12-25-2019 08:16
I had the exact same issue this morning, selected Inspire HR and it connected immediately.
Best Answer12-25-2019 15:52
12-25-2019 15:52
I bought an inspire as well and have been trying to pair it all day. It works when selecting Inspire HR as the device. Thanks for the tip!!!!
Best Answer12-26-2019 06:54
12-26-2019 06:54
Thanks for the post. The box I received as a Christmas gift said Inspire as well. Wouldn’t install until I set it up as the HR version thanks to this forum.
Best Answer12-26-2019 07:45
12-26-2019 07:45
Same thing happened to me. Glad for your post or I could have been days trying to figure out
Best Answer12-26-2019 14:00
12-26-2019 14:00
Inspire will not pair/sync with my Iphone 7 Plus...I have done all the suggestions 3 times...still nothing.
Best Answer12-27-2019 01:18
12-27-2019 01:18
Best Answer12-27-2019 11:31
12-27-2019 11:31
Ya, me too. My iPhone 8plus doen't list the fitbit as a discoverable device (after I did all the troubleshooting steps).
Best Answer12-29-2019 02:57
12-29-2019 02:57
Thank you so much the Fitbit HR worked for me too been trying for days what are they thinking of I nearly threw it across the floor lol 😂
12-30-2019 10:59
12-30-2019 10:59
I was having this same problem. I called Fitbit support line. They were so helpful. it ended up that I had purchased a fitbit inspire HR even though the box said fitbit inspire. So it did connect when I used the inspire HR. had bought this fitbit from Amazon. So if this is your frustration, give it a try. Maybe you just got and upgrade without knowing it!
12-30-2019 11:24
12-30-2019 11:24
Best Answer12-31-2019 01:00
12-31-2019 01:00
So glad I found this! I specifically bought an Inspire and NOT the HR because it was cheaper. My receipt even said Inspire. I was ready to throw this thing in the trash after getting it for Christmas and by syncing it as an Inspire HR it finally worked. THANK YOU!!!
Best Answer12-31-2019 01:04
12-31-2019 01:04
Oh my goodness yes! This worked. I have an Inspire and have been trying for hours to get Bluetooth connected and nothing worked (despite deleting, redownloading, turning phone off and on again countless times etc). I definitely have an Inspire but when I restarted the process and said it was an Inspire HR it worked!! Thank you so much !
12-31-2019 03:00
12-31-2019 03:00
This was very helpful. I chose Inspire HR and it worked. They should mark that somewhere so people know to try it. Wasted an hour with repeated attempts to connect with Inspire.
Best Answer01-06-2020 08:47
01-06-2020 08:47
HAHA!! That was it!
After two weeks of screwing with thing and contacting Fitbit people who couldn't help (even though so many people had the exact same problem,) it was that the device was an Inspire "HR" and not just an Inspire. My box doesn't even say "HR" on it. I went into the setup and entered a different device, and BOOM, it was syncing. Thank God I read your post. I was sending this thing back today. Awesome! Thank you!
01-12-2020 12:57
01-12-2020 12:57
I am having similar issue. I was able to set up my Fitbit inspire and sync to my iPhone 8. All apps are up-to-date. However, my Fitbit was not syncing yesterday (day 2 of owning it) so I uninstalled everything and tried to resync last night- no luck. Was able to sync this morning but it is now 2:00 and it is de-coupled and will no longer sync.
what can I do?
Best Answer01-12-2020 15:06
01-12-2020 15:06
Best Answer01-13-2020 06:07
01-13-2020 06:07
You know what the problem was? The problem was that they don't bother to tell people that their Inspire is actually an Inspire HR, so customers waste a lot of time trying to figure out why their brand new device isn't working, even though they're following all of the directions.
Thanks for replying...lots of frustrated people out there, apparently.
