Inspire won't show the correct time
ANSWERED
The time shown on the clock face is wrong.  How do I adjust it?  It stopped while connected to the charger and started again when charger disconnected so is now several hours out
1 BEST ANSWER
Accepted Solutions
Hi there, @Ditag7. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire.
I was wondering if after charging your Inspire, you synced it?  Keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account.
Also, note that the time on your Fitbit Inspire may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Inspire is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
I've moved your post to the Inspire & Inspire HR board for organization purposes.
Hope that helps.
1 REPLY 1
Hope that helps.
