03-22-2019 16:14
03-22-2019 16:14
My Inspire paired with my Samsung J3 just fine, but wouldn't sync. I've given up, uninstalled, and am syncing to a less convenient device.
03-22-2019 18:58
03-22-2019 18:58
Let's figure this out....... Can you go under Bluetooth in your phone and see if the device is at least listed in the connected devices? If not, does your tracker show up as a device that can be paired?
What device are you using to Sync now?
Best Answer03-22-2019 19:01
03-22-2019 19:01
Best Answer03-22-2019 19:06
03-22-2019 19:06
Ah okay, make sure both devices don't detect the same watch.......
Then remove the Inspire from your account on the Fitbit App and remove it from the list of devices. I think its called Forget.
Then turn off the tablet. Uninstall the Fitbit App on your phone, restart the phone, then reinstall the app.
With the watch on the charger hold down the button on the left for 5 or 6 seconds and the device reboots.
Take it off the charger and start the device setup.
You should be able to install the device after that.
Best Answer03-22-2019 19:12
03-22-2019 19:12
Best Answer03-22-2019 20:21
03-22-2019 20:21
Just a thought does your Galaxy J3 have an Android OS Update that is pushed out by either Samsung or your cell carrier? Sometimes these major Android OS updates can help with the Fitbit app compatibility wise, or break them.
