05-22-2019 23:16
05-22-2019 23:16
My inspire hr has been working just fine for like a month now all of the sudden it won’t turn on. I’ve had it plugged in charging all day. The charging port/ charger is clean. It will just vibrate and sometime show the smiley face but that’s it. I also tried the 5 second holding tip, doesn’t phase it. It still won’t work. Also my phone can’t seem to find it now.
09-26-2020 18:46
09-26-2020 18:46
not able to get mine started either. its just dead. any information other than plugging it in, holding it for 5-10 seconds? nothing happening? I have used different plugs, been plugged in for hours...nothing. Ann
09-27-2020 08:28
09-27-2020 08:28
09-27-2020 16:00 - edited 09-27-2020 16:42
I can't get my stated either. It worked fine yesterday and died overnight. I plugged it in this morning and still nothing. I have tried the reset, holding for 5 seconds, nothing. I have tried this several times, still nothing. I had it plugged in originally then switched it to my computer, still nothing. I removed it from the app and now it can't locate it. I got this one in April 2020. Any suggestions would be greatly appreciated. Thanks Rhonda
09-27-2020 18:07
09-27-2020 18:07
I’ve had my Fitbit inspire for over 2 months now and it does not turn on any more. I’ve restarted my Fitbit while plugged in numerous times. But when not plugged it it does not turn on, and the app show that the battery life is at 1% and will not charge even when plugged in.
Please help.
09-27-2020 18:41
09-27-2020 18:41
Mine is having the same issue. I’ve plugged it in with two different charges, tried resetting it, cleaned it, plugged it in and tried a rest - nothing! Did you ever get a fix?
09-27-2020 18:50
09-27-2020 18:50
10-07-2020 03:53
10-07-2020 03:53
Hello Grace. I also have the same exact issue with mine. It just happened this morning. Can you create a case on my behalf as well?
10-07-2020 05:08
10-07-2020 05:08
I’m sorry but I can’t help you with that I got a new Fitbit so I can’t helo you I’m so very sorry
10-07-2020 12:59
10-07-2020 12:59
10-07-2020 13:09
10-07-2020 13:09
10-12-2020 19:58
10-12-2020 19:58
Nope. 7 months old and just stopped. Had 2 smiley faces and the disappeared. Now absolutely nothing. Extremely disappointed.
11-03-2020 09:55
11-03-2020 09:55
A similar thing happened to me. I’m guessing you’ve already done this, but I would try holding the button for 5 seconds 5-10 times in a row. Nothing was happening, but then it started working. The clock is still almost 3 hours off, but everything else seems to work. Good luck!!
02-05-2021 07:16
02-05-2021 07:16
I am having the same issues. I tried to restart it, but still nothing appears. What else can I do to reset it?
04-23-2021 08:48
04-23-2021 08:48
Same. Not doing anything. Yesterday I tried to sync and it wouldn’t connect. Was able to do the plugging in and resetting. Today, nothing. It’s been charging. It’s been deleted from my account. I can’t even get it to turn on at all. So frustrating. I hadn’t replace my last Fitbit a few years ago because this seemed to be a common issue I kept having. But work provided us with one for a fitness initiative. And I got my daughter one so we could do this together. But now, the issue seems to continue. I don’t have these issues with my Apple Watch.
11-11-2021 09:06
11-11-2021 09:06
It just happened to me. CS told me to change the clock face thru the app. It worked!
11-12-2021 06:32
11-12-2021 06:32
Hi I’m also having the same problem, my Fitbit won’t turn on, I’ve charged it and tried holding the button for 5 seconds but still won’t work.
Is there anything else I can try?
12-17-2021 07:42
12-17-2021 07:42
09-23-2022 09:03
09-23-2022 09:03
Thanks for that information -- my inspire was acting like your husbands -- Did the same thing and it began working again -- So glad I checked here
09-24-2022 03:55
09-24-2022 03:55
Me too, my Inspire HR was working fine till this morning when I sync my sleep;
Then the screen blanked out & the tracker stopped functioning;
No green light behind the tracker, no bluetooth / sync with iPhone App, no charging works, no reset works, no nothing suggested on the web helps to revive it; even Fitbit Help Support did not allow me to post my issue to them!
Please can someone help advise; really appreciate.
Thank you! God bless!
04-15-2023 13:10
04-15-2023 13:10
My inspire 2 has just decided it wanted to turn off at 70% battery does not seem to want to turn back on. I have read through this thread related to similar issues. Are there any other remedies?
