07-24-2019
21:59
09:32
07-24-2019
21:59
09:32
Last night my Inspire was perfectly alright, I charge it before I went to bed then after 2hrs when I checked it if its fully charged no light coming out in the screen,so I tried to restarted it (put back on the charge and press the button for 5sec) but nothing happening I cant see the smile face in it...usually when u put the inspire in the cable charging it will vibrate means it's working now it wont vibrate....so pls help me to solve this problem. Thanks
07-25-2019 01:18
07-25-2019 01:18
Hi @annasui10 I have flagged a moderator to come and help you
Helen | Western Australia
07-25-2019 09:55 - edited 04-22-2024 05:59
Welcome to the Community Forums @annasui10! Thanks for troubleshooting your Inspire prior to contacting us.
Since none of the steps you tried have worked, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community Forums.
Hi @NellyG, thanks for your help and flagging the post.
07-25-2019 09:56
07-25-2019 09:56
Thank you😊 I chatted with the fitbit support and they opened case for it after doing all the help they suggested, so I'm just waiting for the reply from technical support.
07-25-2019 09:58
07-25-2019 09:58
Thanks for replying, yup, just waiting for them to contact me, I hope it will be fix soon.
08-05-2019 14:24
08-05-2019 14:24
Update! They decided to send me a replacement for my fitbit inspire and I just received it today...🤗 thanks
