08-11-2023 14:16
08-11-2023 14:16
My Inspire2 is about 1.5 year old, and now its not useable. I have no idea how to contact FitBit to get a resolution as clearly the product was defective.
What happened is where the band attached to the fitbit, on the fitbit side, the connector that allows the band to attach securely is broken, not allowing a band to stay securely on. This was not caused by any excessive treatment on my part, or any cleaning solution..etc deteriorating the plastic, but rather it seems the plastics simply gave out. Now it is essentially useless, and this is very frustrating as it is sitting on the shelf.
Who can I reach out to at FitBit to get a resolution on this?
08-11-2023 16:58
08-11-2023 16:58
Hi @Sandy_Ottawa if you're under warranty, get with support. Since you have the Inspire 2, you are able to use it with the optional clip.
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
