03-06-2019
07:38
12:19
ErickFitbit
03-06-2019
07:38
12:19
ErickFitbit
I want to purchase the new Fitbit Inspire HR, I have previously had the Alta HR. Are the bands the same for both of these devices? Thanks
Moderator edit: edited title for clarity
Best Answer03-06-2019 07:43
03-06-2019 07:43
Hi @lmhamm Welcome to the forum. Alta HR band will not fit on your new Inspire. Inspire and Inspire HR have interchangeable band, but they are not compatible with older Fitbits. I just started wearing an Inspire and love it. I hope you enjoy yours too. Best of luck on your journey to a healthy lifestyle.
03-06-2019 08:19
03-06-2019 08:19
What are the dimensions of the tracker itself (LxWxD) without the band?
I'm trying to compare the size of the Inspire to my Alta.
Best Answer03-06-2019 08:33 - edited 03-06-2019 08:35
Hi @rveez I'm having a hard time finding the official measurements, but in comparing it to my Alta, it's is the same length and a tiny bit wider, but sits flatter on the wrist.
03-06-2019 11:13 - edited 03-06-2019 11:15
@rveez @lmhamm Great to see you on the forums!
Just wanted to confirm that the Alta HR bands are not compatible with Inspire or Inspire HR.
@rveez Great question. I will follow up with our team to see if we can get those measurements for you. Though I can say from experience that the pebble is about as wide as Alta and it feels a lot less bulky on the wrist. I'll let ya know if I can get the exact dimensions from our team.
@MarciM Thanks so much for the assistance!
Looking forward to hearing feedback on Inspire. Feel free to let me know if you have any questions!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
Best Answer03-06-2019 11:17
03-06-2019 11:17
@MarciMAre the Inspire and the InspireHR the same size? The description says the clip only works with the Inspire, and not the InspireHR. I understand that you can't measure heart rate on the clip, but what I want is a device to wear on my wrist and measure HR when working out, and then to keep in a clip the rest of the time.
Also, the specs don't say anything about either Inspire measuring flights of stairs. Does it? If it really doesn't, that's a big reason not to buy it for me.
03-06-2019
11:25
03:37
03-06-2019
11:25
03:37
@SunsetRunner The Inspire and Inspire HR do not count floors/stairs. This is to keep it slim.
The clip only works on the Inspire, as the heart rate monitor on the Inspire HR makes it a little too big for the clip. Maybe in the future there will be third-party clips that will fit the Inspire HR.
03-06-2019
15:43
03:37
03-06-2019
15:43
03:37
@rveez and anyone who is interested, my product team has gotten back to me with the pebble specs for Inspire HR:
Width: 16.2mm
Length: 37mm
Height (wrist to top of device): 12.6mm
@MarciM I can confirm that the Inspire HR is about 1mm taller than the Inspire base model, due to the HR monitor. Width and length are the same.
@Heather-S Thanks for the help!
03-08-2019 05:27
04-07-2019
15:37
17:23
JuanFitbit
04-07-2019
15:37
17:23
JuanFitbit
yes, inspire or inspire are same bands. but that be said very hard to change the band. took me 45 min to change min. I had the alta hr before and took a couple seconds but the design on this is not great. I advise you to 1. be sure you don't loose the little (I do mean tiny) metal part that locks it in place as you will need that on any other bands you get. 2. don't do this if you are in a hurrry as it is a slow process, well worth it but slow process!!!
I
Moderator edit: format
Best Answer04-06-2020 21:47
04-06-2020 21:47
Is Fitbit inspire sangria colour Band suit with Black inspire HR?
Best Answer04-08-2020 19:19
04-08-2020 19:19
Best Answer04-09-2020 07:35
04-09-2020 07:35
@Mahekan - If you are asking whether the sangria band would look good with the black Inspire HR, then my answer is yes. I believe they would look very nice together.
