09-02-2020
08:03
10:13
AndreaFitbit
09-02-2020
08:03
10:13
AndreaFitbit
Will the inspire hr bands be compatible with the inspire 2?
Moderator Edit: Formatting.
09-02-2020 10:39
09-02-2020 10:39
@Angel_kompletu Welcome to the Fitbit Community!
Thank you for your inquiry about the Inspire 2 bands compatibility. The Inspire 2 won't be compatible with previous Inspire wristbands.
Let me know how it goes.
Best Answer09-02-2020 10:39
09-02-2020 10:39
Best Answer09-02-2020 10:50
09-02-2020 10:50
To bad 😞 , got some new bands just before my inspire hr's display stopped working.... might purchase another hr instead of the 2.
Best Answer09-27-2020 18:54
09-27-2020 18:54
Sorry to butt in - I have purchased several bands made for previous Inspire version from Amazon (can I say that?) and the fit is fine. No problems so far, they were stainless bands if that makes a difference.
09-28-2020 15:13
09-28-2020 15:13
Thanks for the info. I've been wondering about that. Amazon has several listed stating they fit the Inspire 2. Further in the descriptions listing the compatible devices the 2 is not listed. And of course here it says they're not compatible. Seems weird if there is a difference that someone hasn't come out with new ones. Even when checking Google I can't find anything specifically for the Inspire 2. Would be interested in hearing from others here who have the older model and whether or not they have issues with fit.
09-29-2020 12:37
09-29-2020 12:37
The Inspire band does fit the Inspire 2 model, however, it does leave a small gap between the device and the band. Actually looks like the same issue with the Charge 4 device leaving a gap in between.
The case covering that currently is being sold on Amazon that says will fit Inspire and Inspire 2 is inaccurate. I put the Inspire case on the Inspire 2. Although the case fits, it is not a perfect fit as the Inspire 2 device is slightly shorter than the Inspire.
04-20-2021 17:50
04-20-2021 17:50
I think you are right, as long as the band says Inspire 2 or HR not just Inspire it works fine
04-23-2022 21:30
04-23-2022 21:30
Would the case being a bit longer help cover the gap? I’m not going to lie. The color choices for the Inspire 2 do not excite me one bit. I’m rather happy with the coloring of my lilac HR. Black isn’t my cup of tea. And the pink is too bright in real life for my cup of tea. The white is pretty but the black device is a bit disappointing.
