Is is possible to uninstall apps on Inspire HR tracker?
ANSWERED
Is there any way to uninstall apps on the tracker? or at least remove them from the scroll screen? not to be a pain in the butt, but is it possible to lower the screen sensitivity? i try to scroll and the screen goes black
1 BEST ANSWER
Accepted Solutions
Hi @jojobee No, you cant remove or change the position of apps on the Inspire (which I find a bit annoying too!). I find mine doesnt pick up my scrolling well if the screen is wet (eg in the pool or shower), so make sure your fingers are dry when you want to scroll.
Community Council Member
Helen | Western Australia
1 REPLY 1
