09-18-2019
07:44
14:44
SilviaFitbit
09-18-2019
07:44
14:44
SilviaFitbit
hi there,
can you let me know how I can make the face on the watch brighter? I find it very hard to read when outside (not even in that bright of light/ sun) which makes it difficult to see step, exercise etc.
How can I make the face brighter so I don't have this issue anymore?
Best Answer09-19-2019 14:40
09-19-2019 14:40
It's great to see you around @Redlionny. Thanks for the details mentioned.
It's not possible to change the Inspire's screen brightness. I was making some research and you might want to try this tip mentioned by one of our councils here.
Best Answer09-27-2020 15:09
09-27-2020 15:09
This makes this gadget completely
USELESS!!!
IT WAS A GIFT NOW GOING TO .....
11-08-2020 02:49
11-08-2020 02:49
YES! You can!!! I had the same issue and couldn't believe it wasn't an easy change to do in "settings" BUT- if you go to the watch screen itself and swipe around, an option to "turn off dimming" comes up (not sure why it would be set to dim to begin with). Once you turn it off, the screen brightens and makes the watch useful indoors and out! I hope this helps!
12-09-2020 17:50
12-09-2020 17:50
You can change the setting for the Inspire 2 to make it brighter just hit the sides of the Inspire to get the menu button and go down a unmarked sleep. It will have a line through it when u turn sleep off
12-27-2020 10:43
12-27-2020 10:43
Just tried that and it worked! Finding it hard to navigate through the menus—I keep randomly turning things off and on! Good to know about the no-sleep option to make it brighter.
Best Answer12-30-2020 16:40
12-30-2020 16:40
Thanks Ramfamnh that worked great! So nice to be able to read the screen now.
Best Answer02-01-2021 13:43
02-01-2021 13:43
Yes, it worked for me just now. Thanks!
Best Answer03-14-2023 15:16
03-14-2023 15:16
WRONG! Turn Inspire 4 on and swipe to left several times until you reach settings. You can choose from dim, normal or auto for brightness.
Best Answer03-14-2023 15:17
03-14-2023 15:17
