06-22-2019
08:32
11:17
YojanaFitbit
06-22-2019
08:32
11:17
YojanaFitbit
Is the HR monitor on the Inspire HR flush/flat on the underside of the tracker? I have a thin, bony wrist and tried to wear the Charge HR a few years ago. The little square HR monitor pressed into my wrist between the bones, regardless of how loose I wore it, and irritated my skin to the point the skin wore off. So again, does the monitor stick up from the underside of the tracker?
06-23-2019 11:10 - edited 06-23-2019 11:27
Hey @NCFlyGirl how are you doing? Nice to see you again.
I really appreciate you've posted your question here. I'm sharing with you the images of the Fitbit Inspire HR and other two options that you might consider in your next purchase. Please take a look of them, I think that if you follow the wear and care Fitbit tips, you shouldn't have issues with your wrist.
You can also compare features of these three devices here.
Fitbit Inspire HR Click here to have a 360° view of this model.
Fitbit Charge 3 Click here to have a 360° view of this model.
Fitbit Versa Click here to have a 360° view of this model.
Let me know if you have questions about this.
06-24-2019 17:56
06-24-2019 17:56
Thank you Yojana. I was considering the Inspire HR since it looks like the smallest of the three you showed. I wear an Alta and would like to know how thick the body of the Inspire is in comparison to the Alta. The inspire looks thick to me.
Thank you in advance.
