06-06-2019
18:55
08:23
YojanaFitbit
06-06-2019
18:55
08:23
YojanaFitbit
My data was accidentally cleared from my Inspire. Is there anyway to get it back?
06-07-2019 08:19 - edited 06-07-2019 08:21
Hi @sueross429 welcome to the Community Forums. ![]()
Thanks for sharing your question here. At this moment, we don't have an option to restore your data once it has been cleared by using the option "Clear User Data". In that case you need to follow the set up process again and start from scratch.
Let me know if you have questions about this.
08-20-2019 14:18
08-20-2019 14:18
I recommend Fitbit to change the functionality where an user can easily erase data by accessing the 'Settings' feature on their Fitbit Inspire & holding it for 3 secs. That's wrong design!!!
10-04-2019 11:36
10-04-2019 11:36
Somehow my Inspire HR has the Clear User Data on the screen but I don't want to clear it. How do I get rid of that message without actually deleting the data?
Best Answer10-04-2019 22:10
10-04-2019 22:10
Lol @JimLM use the back button to get off that screen (I do understand your reluctance to do the wrong thing!). Hope you have managed to get off that screen by now.
Helen | Western Australia
11-13-2019 08:58
11-13-2019 08:58
I accidently just did this too trying to figure out how to make my watch buzz with reminders to move. This is the STUPIDEST FEATURE! I do not care why someone might want to do this, it should be more difficult to do and need to be done from the app or from a computer WHERE THEY CAN PUT WORDS THAT TELL YOU WHAT EXACTLY IT IS DOING!? Get it together, fitbit, we are all tracking our every move because we want the data! Super, super stupid feature. I am sure there is something much more useful you could put in that watch space, so hurry up and do it.
03-25-2021 17:46
03-25-2021 17:46
Clear User Data. Boo!!! Bad idea. I accidently went there, unfortunately. At least have an "are you sure" confirmation.
07-16-2021 13:02
07-16-2021 13:02
I have done the same just playing around with the device. Now it won't sync. I have tried to set it up again but when I click on the inspire hr it says its already set up and there is no option to do anything else. Now what?
07-17-2021 01:04
07-17-2021 01:04
Hi @BAMGIRL Have you tried restarting both your Inspire and you phone? If not give that a try and then see if it will sync. If you still have problems then try THIS Help Article on Syncing problems.
