10-11-2019
09:44
10:25
JuanJoFitbit
10-11-2019
09:44
10:25
JuanJoFitbit
Since getting my Inspire HR earlier this year, my wrist has been periodically itchy from the band. I previously had the Flex, Charge HR, & Alta HR and had no problems with the bands. This band has been affecting my wrist since the beginning. The tattoo is 8 years old so has nothing to do with what is happening now. Has anyone else had this happen?
10-11-2019 18:36
10-11-2019 18:36
Yes I had a similar reaction, that lasted for a couple of weeks. I happened to have a tube of clobetasol propionate cream leftover from a bout of poison ivy a few months ago and a few days of applying the cream cleared up my wrist. That was a couple of weeks ago and it has not (yet) shown any sign of renewed irritation.
In case something got on the band I'd try cleaning it and rinsing well.
10-11-2019 23:23
10-11-2019 23:23
I’ve used a cream (Triamcinolone Acetonide) that helps with the itch but it comes back again. I’ve cleaned the band several times with both soap/water & rubbing alcohol. I’ve never had anything like this before.
10-12-2019 21:44
10-12-2019 21:44
Sounds like you might have a sensitivity or allergy to the band material or the metal of the buckle. That was my fear when I first got irritation soon after getting it, I was surprised the cream I had seems to have fully resolved it. I had metal glasses that irritated the skin behind my ears once, a kludgey fix for that was plastic coating around the metal, though they were under warranty so I was also able to have them replaced with non metallic. If it is just the metal bit I wonder if there is anything you could coat the metal bit with to help stop the irritation.
10-14-2019 12:25
10-14-2019 12:25
Same issue here, iv swapped wrists a few time, did the cleaning and wipes, have to say it's calming down after a months.
10-14-2019 14:00
10-14-2019 14:00
I’ve switched wrists, too, but shortly after putting it back on my left wrist (non-dominant), the eruptions occur. I’m thinking of getting the leather band and see if that helps.
02-01-2021 13:52
02-01-2021 13:52
I've also had / have this problem with an itchy rash that occurs on the wrist I am wearing my watch on. It irritates me that much I take off my watch and then don't use it for days.
Has the leather strap helped you?
02-01-2021 20:00
02-01-2021 20:00
