12-22-2019 03:26
12-22-2019 03:26
Since about 5 hours the Fitbit wrist band showing no screen although it registers all data and can be read on phone .. pressing push button failed to show screen status.. what possibly has gone wrong and what needs to be done..
Best Answer12-22-2019 04:21
12-22-2019 04:21
@Mloan, which Fitbit tracker do you have?
Best Answer12-22-2019 07:26
12-22-2019 07:26
Inspire
Been using it 3+ months
For swimming too
Happened today first time .. no water involved for 48 hrs
Best Answer12-22-2019 07:35
12-22-2019 07:35
Thanks for the reply, @Mloan. I moved this thread to the Inspire Help Forum, since it is specific to this device.
Best Answer12-22-2019 11:17
12-22-2019 11:17
Best Answer12-26-2019 03:17
12-26-2019 03:17
Dear All
I suffered black screen on Inspire device about 11am.
after 8-9 hours, I took extreme measures and took off the strap by manipulating the pin connector and started using brush to clean off any dust rubbing vigorously ..
And voila within no time my screen lit up
Now which hidden vibes got generated to light the LED display I do not know
