Looking for a portable charger that IS compatible with my FitBit's ...
We have a Charge 2 and an Inspire HR … also have 3 mini chargers that carry the brand name Pocket Juice … we use the chargers a lot to charge our phones on the go … they work great.
But they don’t work with our FitBit’s … even though they have a USB port for that purpose …
I’ve talked with Tzumi, the mfg of the Pocket Juice products, and they agree they aren’t compatible with FitBit, but “they say they don’t know why” …
Does anyone know of any portable chargers that DO work with FitBit products to charge them on the go?
Thanks for your help!!
3 REPLIES 3
Hi @JDBear  I finished experimenting with my power banks to see which of them will charge my Alta HR.  All three show it as charging the Fitbit and I was able to restart the device while it was charging.
1. Aduro PowerUp 11,000 mAh Portable Backup Battery Model PW-11KO4-BT- from Amazon
2. PURIDEA S5 7000mAh Power Bank - from Amazon
3. Ubio Labs 10,000mAh Portable Charger - from Costco
These last ones did NOT work
4. Morphie - small (size of a roll of quarters) - from Costco/Verizon
5. Aduro 10400mAh Charger IP54 - Hobby Lobby
6. IHarbort 10000mAh Ultra-Thin Aluminum 2 port
So, it seems no two Aduro power banks are alike when it comes to charging the Fitbits!
Hope you find the right one for your Fitbits.
Stepping in the U.S.A. since September 2013. Android 14
Wow, thanks for the extensive and very helpful reply . So I'll see if I can
get my hands on one of the ones you have found that works, and problem
solved . Thanks again!!
@JDBear  found one in my car that works, too.
Puridea S2 External Battery Pack 10000mAh from Amazon
