10-18-2021
12:48
16:32
AndreaFitbit
10-18-2021
12:48
16:32
AndreaFitbit
I am a longtime Inspire HR user and my latest one has been showing signs that it may be time to replace it. Looking for feedback - trying to decide if I should stay with the Inspire 2, upgrade to the charge 5 or maybe go crazy and get the Versa 2. I am not a very "techy" person (it did take me awhile to completely figure out all the functions on my Inspire HR but I do fully use it and an can troubleshoot it with no issues) and I have a very small wrist so the Versa 2 may be too much for me.
10-18-2021 13:03
10-18-2021 13:03
Hi @Momeismom I had the Alta HR, which was the generation before your Inspire HR. Got the new Luxe and it's perfect. It's also good for the smaller wrist people. The Charge 5 is the newest device released and it's more techy than the Inspire HR. You should go with what you feel drawn to. Take a look at them at the Fitbit Store, linked upper right of this page. I'm sure you'll find the one that best suits you.
10-19-2021
16:48
12:22
10-19-2021
16:48
12:22
Welcome to the Fitbit Community, @Momeismom and thank you for your advise @Odyssey13.
I also have a very small wrist and wear a Fitbit Luxe like @Odyssey13, It's small and simple to use but I would recommend checking our products at the Store and decide which is the best for your needs.
Have a wonderful day!
10-21-2021 04:04
10-21-2021 04:04
@Momeismom If you are really happy with the Inspire HR features, then the built in GPS, ECG (if available in your country) and EDA in the Charge 5 might be way more than you want or need. The color display on the Luxe is much better than any monochrome display, like the Inspire HR. I can read it in sunlight!
Just adding my two cents.
Laurie | Maryland
10-23-2021
07:03
12:22
10-23-2021
07:03
12:22
Thanks for getting back to us and for sharing your thoughts @LZeeW.
I hope @Momeismom, let us know about final decision.
Keep on visiting the forums.
10-24-2021 07:30
10-24-2021 07:30
I think it depends on the features you want to use, @Momeismom. The color screen is easier for me to see in the sunlight so I would go with something like the Luxe if you can swing it.
one cruise ship at a time!10-24-2021 08:49
10-24-2021 08:49
My impression is that you are very happy with the Inspire HR—I have this device too! I have owned my device since April 2019. I am here to find answers to whether or not to replace my Inspire HR with the Inspire 2 or “upgrade” to something like the Charge 5. My thought is that I would update to the Inspire 2–since it is what I know. However, my eyes are getting older, I do a lot of outside walking, it would be very helpful to see how I’m doing on my Inspire HR while outside. Hence my thought that I would upgrade to the Charge 5–with its color screen, it is supposed to be visible in bright light. Is that a good enough reason to pay that much money to be able to look at my information in the sunlight? But it is not as costly as the Versa 2.
10-25-2021
19:47
12:20
10-25-2021
19:47
12:20
Thanks for getting back to us and for your comments @DramaQueenDiva, @MattWoelfsen.
@MattWoelfsen, you can check product information at the store.
