Milage vs steps taken
My tracker is no longer adding milage correctly. I now have 14000 steps and my milage today is only 3 miles. Normally it would be closer to 6 miles
3 REPLIES 3
@Perkins621 , A warm welcome to the Community! Thank you for your message.
Do you use GPS when recording your runs?
How do you record the walks/runs/steps?
In the meantime, please verify that your personal settings are correct( high, weight, gender, etc)
If you haven't done so, customize your stride length
See you around.
This happened to be too except I Fitbit turned all my runs that were over 10,000 into 2,000. For the last couple weeks it has only recorded over 2000 one time.
@BlingJunkie  Nice to see you around.
I'm not quite sure to have understood your situation.
Do you mean that your recorded/synced  activities have changed?
Do you record an activity, it syncs with the right data, and then it changes?
Could you please elaborate on what's going on and what have you tried, so I don't ask you to do it again, if not needed.
See you around.
