01-07-2020 16:09
01-07-2020 16:09
Got an Inspire HR for Christmas a couple of weeks ago and today it decided that the screen will not turn on just by rotating it to my face like it should.
If I press the button the screen will display, however this is not always convenient.
Checked out the forum, didn't find quite the same problem. I did try the restart, however this did not solve the problem.
I am using an iPhone as the syncing device.
Any advice would be appreciated.
Thanks.
Best Answer01-07-2020 16:32
01-07-2020 16:32
Sorry, predicted text......... Hi, Have you turned it of on your Fitbit by accident,. If you hold the button on the side it will show you how much battery you have left, scroll down and you have the choice of "screen wake" if it has a line through it, then it is off, just tap on it to turn it back on.
01-07-2020 16:29
01-07-2020 16:29
Hi, I have turned it of on your Fitbit by accident,. If you hold the button on the side it will show you how much battery you have left, scroll down and you have the choice of "screen wake" if it has a line through it, then it is off, just tap on it to turn it back on.
01-07-2020 16:32
01-07-2020 16:32
01-07-2020 16:36
01-07-2020 16:36
Yes, that was it. That was too easy. I wondered if there was a setting I didn't know about.
Thank you.
01-08-2020 11:36
01-08-2020 11:36
You welcome, I did it to mine when I 1st got it and by accident of fiddling with the Fitbit figured it out after a few days! I find it really handy now to see how much battery I have left without having to look at the app.
Best Answer09-06-2020 16:18
09-06-2020 16:18
Thanks.
Appreciate the advice.
Best Answer12-07-2020 04:56
12-07-2020 04:56
That's exactly what happened......thank you!
Best Answer03-04-2021 09:20
03-04-2021 09:20
Thanks. Worked like a charm. Doesn't happen often so I need help remembering how to fix it when it does.
Best Answer06-15-2021 09:53
06-15-2021 09:53
tried this, screen wake is slashed and off, touching it does nothing, can you help?
06-15-2021 09:54
06-15-2021 09:54
I have a Charge 4, I tried this, screen wake is slashed and off, touching it does nothing, can you help?
02-12-2023 15:30
02-12-2023 15:30
Ah, the good ole' search feature... I went through all the settings and couldn't find it on my own. probably did it last like 3 years ago. But searched, found this thread, and voila, have it back on, thanks!
