09-24-2021
08:06
22:58
09-24-2021
08:06
22:58
My fitbit inspire 2 has been brutally scratched it feels like rubbing my finger over concrete. I dont know how but when i turn my fitbit on all i can see it perfect in the dark but when im outside i cant see a thing even when the sunshine is shining what should i do.
09-25-2021 10:26
09-25-2021 10:26
@Reubenday19 Hi there. Thanks for the details mentioned.
If your Inspire 2 screen has been damaged, get in touch with our Support team for additional help.
For the dim screen, check that Dim Screen is turned off in the Settings app and make sure that Sleep mode is turned off in quick settings and in the Settings app. For full instructions check out this article.
Hope this helps.
11-21-2021 18:30
11-21-2021 18:30
Which Fitbit works best outdoors?
11-22-2021 16:26
11-22-2021 16:26
@Bradin9855 Thanks for getting back to us. If you're talking about display brightness, Inspire 2 has the option to turn off dim brightness on the Settings app. You can find this and other details about Inspire 2 features here: Inspire 2 Manual. You can use this model outdoors.
Hope this helps.
08-02-2022 15:37
08-02-2022 15:37
I too have this issue with my inspire2. It has reached a state where I can’t even see the screen indoors. Has anyone found a solution to this other than the settings?
08-03-2022 14:17
08-03-2022 14:17
Dim off or on, I still can’t see the screen when I am outside.
08-03-2022 14:49
08-03-2022 14:49
Ugh same, after less than a year 😞
08-03-2022 15:23
08-03-2022 15:23
Yes, mine was after about 6 mths. I was actively using it along with the free subscription. However the way it’s going they have lost a loyal customer and the ability to recognise recurring revenue. Ok that’s just me but I am sure others have also started looking at alternatives and there are some great options out there. Unless Fitbit does something to fix or do the right thing and replace it, I will not be buying another Fitbit.
08-03-2022 23:32
08-03-2022 23:32
Even when you do as you have instructed it doesn’t work
09-27-2022 21:01
09-27-2022 21:01
Agreed. I have done everything. The screen started getting unusually dim after about a year. It has only gotten worse where I can only easily see the display in pitch dark. I would never recommend the Fitbit because of this. The company knows it has a problem and is not addressing it. It is a faulty product. I am switching to another type of health tracker
09-27-2022 21:02
09-27-2022 21:02
I have done everything. The screen started getting unusually dim after about a year. It has only gotten worse where I can only easily see the display in pitch dark only. I would never recommend the Fitbit because of this.
09-27-2022 21:03
09-27-2022 21:03
Terrible. The company should rectify this somehow.
09-27-2022 21:03
09-27-2022 21:03
Same. Terrible to pay what we did for a product that doesn’t last.
09-27-2022 21:04
09-27-2022 21:04
Me too, and no solution has worked. This product is defective.
09-27-2022 21:08
09-27-2022 21:08
Sorry my Fitbit friend. None of the corrections work, from rebooting, to rebooting while connected to power cord, to changing and unchanging the Dim feature. The device was good for about a year. I purchased in Jan 2021…. I started noticing I couldn’t read the display this year but have suffered through because I like the tracking feature. But it has only gotten worse - I believe the brand or version is defective. Would be nice for Fitbit to admit it. I am on the search for a better device that tracks and has a great display I can read!!.
09-28-2022 00:00
09-28-2022 00:00
Sorry we are well aware of this. It just doesn’t work outside anymore!
09-29-2022 09:12
09-29-2022 09:12
I too am having the issue. The screen has become too dim to use outside. I can hardly read the screen inside. The DIM is off and I have tried several clock faces. Nothing seems to be working, it has just gotten dimmer. I see from this forum that several others are having this same issue. Is there any resolution yet?
11-13-2022 20:31
11-13-2022 20:31
same as everyone else - I’ve tried everything listed here but my screen is so dim that I can barely see it - even in a dark room inside the house
11-14-2022 01:01
11-14-2022 01:01
so frustrating isn’t it. Especially when Fitbit deny it’s actually happening and blame us for not using the correct settings. I won’t be renewing my subscription when it expires.
11-14-2022 11:43
11-14-2022 11:43
Plz reply directly: how to correct problem. ( beyond refer to manual & turn off dim. ) we all know that and that does NOT correct problem! SOLUTION is overdue in 2022!
