My HR has stopped tracking my sleep
Any suggestions?  It's worked fine for the month I've owned it, until two days ago.
Also, I wear mine on my dominant wrist; is there a problem with that?
TIA
2 REPLIES 2
An answer to a similar post said to reset your Fitbit. I’ve had the same issue a couple of times but haven’t reset as mostly it’s working fine. But if it gets worse I will try resetting.
Your settings should be for wearing on your dominant hand/wrist.
Thanks -- yes, that's my last resort.
