01-09-2020
03:01
11:10
YojanaFitbit
01-09-2020
03:01
11:10
YojanaFitbit
I bought the Inspire HR as supposed to automatically recognise my swim but not managing to do this. Firstly recorded my swim twice as eliptical training, so I turned off this option as recommended. Now it doesn't recognise that I've done anything so manually inputting which is a pain. Any advice much appreciated, thanks. I'm on android phone for syncing.
01-10-2020 11:10 - edited 01-10-2020 11:13
Hi @Morbs nice to see you around. Welcome to the Community Forums!
I'll be glad to give you a hand with the information that you need about using your Fitbit to swimming activities. Thank you for the troubleshooting steps that you've tried before contacting us. Sorry to hear that your Inspire HR was tracking your swimming activities as workout activities.
As you may know, your Fitbit Inspire HR automatically tracks your swim duration and pool lengths completed. Please remember to enter your pool length to track your distance and duration. For instructions, see How do I set the pool length for my Fitbit device?
SmartTrack automatically recognizes and records high-movement activities at least 15 minutes long. I'd suggest to confirm the amount of time required for the activity to be recorded.
Your Fitbit Inspire can record your swims even if you were a novice swimmer, meaning you can swim about 6 to 12 lengths of the pool without stopping to rest. As your swimming ability improves, you’ll likely notice fewer inconsistencies in your data.
Please note that inconsistencies in your swim data may be caused by any of the following:
Please confirm that you've followed the restart steps suggested here. If that doesn't work, we might have to check with our support team.
I'll be around, please keep me posted.
01-12-2020 02:19
01-12-2020 02:19
I’m having the same issue with my inspire. I swim for about an hour, no stopping and using same stroke and it does not auto recognise the activity - initially it recognised it as elliptical so turned that off and now nothing. I have restarted the device several times and this doesn’t help. Very annoying to have to track manually as the ability to track swimming was one of the reasons I bought this device.
