My Inspire HR won't sync to my phone anymore
My fitbit stopped syncing so I searched online for tips to fix it. I finally just deleted the app and was going to add it back. When I went to add it, there was no fitbit app in the Play store. After some searching, I discovered that the fitbit app won't play well w/ a samsung 6 with the OS that mine has. I'm not going to buy a new phone so I can get the fitbit app!  When I login on line, my profile continues to tell me that I haven't synced since Oct 17th. arrggghhh Help?
3 REPLIES 3
Hi @funnygirl70  wish you'd come here first and posted. Once you removed the app, you got stuck. If you don't have Android 8 or higher, there is no app available for you and you need the app to sync.  Sorry, but there is no workaround for having removed the app.
Stepping in the U.S.A. since September 2013. Android 14
I searched around online and did the other things that were recommended re: the sync problem. The final step seemed to be to remove the app and add it back. I'm not at all happy with this but instead of buying a new phone I'll guess that I'll get a new tracking device that isn't a Fitbit. 🙁 boooo hisssss
Sorry @funnygirl70  but whatever product you get, if you have a question, go to their page first. Often the suggestions found online can be misleading. We've been trying to tell people not to remove the app since this was happening to others.
