11-27-2022
15:15
20:58
11-27-2022
15:15
20:58
I activated MobileTrack in Fitbit setting to track steps with my phone when I don't wear Fibit. As soon as I did It over thirty-four thousand steps appeared. I deactivated MobileTrack but the steps are still there. Is it any way to delete them?
11-29-2022 02:25
11-29-2022 02:25
Hi, @Raf_007 welcome, this is a known problem when using a Fitbit device and Mobile Track. You need to disable mobile track while your Inspire 2 is paired with your phone.
Cheers
Gr4ndp4 | UK
Best Answer11-30-2022 07:18
11-30-2022 07:18
Hi, I disabled Mobile Track but steps remained. Is it any way to delete steps from Fitbit? It shows I took over fifty thousands steps on that day
Best Answer11-30-2022 07:56
11-30-2022 07:56
Hi, @Raf_007 This article may offer you a way forward How do I add, edit, or delete Fitbit data and activities?
I hope this helps.
Cheers
Gr4ndp4 | UK
12-02-2022 15:11
12-02-2022 15:11
Thanks, logging the activity as Driving did the trick of deleting the steps
