03-06-2020
20:14
07:15
SilviaFitbit
03-06-2020
20:14
07:15
SilviaFitbit
Hi, I'm new here on this Forum. I had a Fitbit ( Charge) before and have the Inspire now.
I'm using the app from before but its now updated and the new Fitbit tracker is added.
The first night I was using my Fitbit it was tracking my sleep, but that stopped working the very next day. There is no data on the app / dashboard of my sleep
and the icon on the device is is grey.
Does somebody know what the problem is?
03-07-2020 07:20
03-07-2020 07:20
@mactube Welcome to the Community. Thanks for letting me know that you had a Charge and now you upgrade to Inspire.
I would like you to change your tracker's settings to sensitive, please check the instructions in this article: How do I track my sleep with my Fitbit device? Since you mentioned the sleep icon on your tracker is grey, please restart it.
Also, please confirm if you have an Inspire or Inspire HR the difference is the heart rate data.
Keep me posted. I'll be around if you have any additional questions.
03-07-2020 16:56
03-07-2020 16:56
Thank you,
I
- changed the settings to sensitive
- restarted the device
- deleted the Fitbit app off my iPhone and reinstalled it
My Inspire HR is still not racking any sleep !
03-07-2020 23:59
03-07-2020 23:59
I hard reset the device, that helped!
Tried it before a nap before work .. result :
Time Asleep : 1h 28 min
Sleep Schedule : 9:13 - 11:25
Sleep Quality :
1 The awake
5 times restless
44min Awake / Restless
Some thing doest ad up ...
03-09-2020 09:26
03-09-2020 09:26
I've had this problem for ages (fitbit HR doesn't track my sleep) and have looked on the user forums for solutions, but none worked. I found the solution to my problem on Reddit of all places, and it works for me: Turn your fitbit around on your wrist so that it's facing the inside.
Hope this works for everyone else as well!
03-11-2020 14:40
03-11-2020 14:40
@mactube Thanks for getting back. In this case, I've shared your post with our Support team and they will continue assisting you through email, please check your inbox.
@Flarb Welcome to the Community. Thanks for your input, I'm glad to hear that when you turned your Fitbit around on your wrist and it faced the inside, it's started tracking your sleep.
03-11-2020 20:35
03-11-2020 20:35
My Tracker magically started working for a day but I will honestly not put up with the device working intermittently and I don't want to remember turning it around before I got to sleep ( which didn't work in my case anyway) I will just have to downgrade again to the older hr model which worked fine.
03-12-2020 13:10
03-12-2020 13:10
@mactube Thanks for getting back. I appreciate that you mentioned you're going back to a HR model.
Don't hesitate to get back if you have any additional questions.
