04-26-2020 11:44
04-26-2020 11:44
Hi all, I got the new iPhone SE that was released on Friday 24th April, I’ve been fighting with the Fitbit app all weekend as my Fitbit wouldn’t sync- I’ve just looked and I’m not sure the new phone is supported/ compatible with the app.
Can anyone help? Has anyone had this problem?
😱🤦🏻:female_sign:😱🤦🏻:female_sign:
Best Answer04-27-2020 00:55
04-27-2020 00:55
Do you still have your old phone? If so, make sure it doesn’t still have a connection to the tracker in its bluetooth settings as this could be blocking connection to your new phone.
Best Answer04-30-2020 09:09
04-30-2020 09:09
Steve is correct. You need to remove that old iPhone from your accounts on the new SE else the Fitbit continues to try and sync with the old iPhone. Go to Settings and click on your Name (Apple ID) and delete the old iPhone.
Best Answer05-23-2020 13:28
05-23-2020 13:28
I tried that, still doesn't work.
Best Answer05-23-2020 14:27
05-23-2020 14:27
If your iPhone replicates to another Apple device make sure that old device is not referenced there as well.
Best Answer11-07-2020 19:38
11-07-2020 19:38
Curious to know if you ever figure this out? I just got the SE. my watch says it’s connected and it still syncs, but it no longer shows my text messages. Driving me crazy!!
