08-30-2019 11:18
08-30-2019 11:18
Do I need to have the bluetooth enabled all the time on my phone? I don't use earphones or anything with bluetooth. Thanks
Best Answer08-30-2019 12:18
08-30-2019 12:18
There is an option in the app in the device settings to have the Fitbit device always connected to the phone which means it will sync in the background at regular intervals during the day. This will need the Bluetooth to be on all the time and will likely speed up battery drain of the phone.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer08-30-2019 11:58
08-30-2019 11:58
No you do not need bluetooth on all the time unless you have set the device to be always connected. You will need bluetooth on when you sync.
Best Answer08-30-2019 12:13
08-30-2019 12:13
Thanks. By having what device to be always connected, the phone or the Fitbit?
08-30-2019 12:18
Best Answer08-30-2019 12:36
08-30-2019 12:36
OK I gotcha. Thanks a lot!
