07-22-2019 23:59
07-22-2019 23:59
I used the option 'workout' before class to change the name later. However, the option 'Body Attack' doesn't exist. What is the second best thing?
Best Answer07-23-2019 02:20
07-23-2019 02:20
Hi @DoraSantos91 You have done tje right thing, in using 'workout'. The best thing to do now is to create a custom exercise called Body Attack. The instructions are below. Once it is created in the Website Dashboard it should appear on your list when you go to change the name.
ADDING A CUSTOM ACTIVITY
First you have to know how many calories you burn in your activity. You can google calorie calculators
Then go to the Fitbit website Dashboard (not the app) and tap the top of the Recent Exercise tile. A little thing will drop down on the bottom of the tile. Tap See More which is on the right side. A new page comes up. Move right to the bottom of this new page to the box titled Activities which is on the right side at the bottom. On the bottom of this box, in blue and small print it says Create Custom Activity. Tap that and a box comes up. Put in the title of the Activity and then fill in the start time and duration of you latest session, fill in the calories burnt and hit log. You have now created your custom activity. Bit of a trial, but you only have to do it that way once.
Helen | Western Australia
07-23-2019 02:20
07-23-2019 02:20
07-23-2019 02:42
07-23-2019 02:42
Hi Nelly,
Thank you for the incredibly detailed response, it was easy to add the custom activity 'Body Attack', which replicates exactly the 'workout' one I had.
Best Answer07-23-2019 03:06
07-23-2019 03:06
Glad I could help 😊
